How to get brighter image in OCR Training?
The Image appears with Dark Background when it is loaded to train characters using OCR Training. But the image is very clear when it is opened with Micosoft Image and Fax Viewer or any other image editor.
Please advice how to get a brighter image while training charecters though OCR Training?
Thanks in advance
Shekh
(3,470 Views)
can you post the VI that you made...
Smiley Wink
(3,463 Views)
Hi, Br.anand
I have attached one example for your reference, this displays the image as black background when image is opened with OCR- Traning
The Image is used to train characters to create ".abc file" using NI-Vision (OCR-Training).
(3,453 Views)
Please do not post bitmap images!
Although you posted an image that as a .jpg extension it is not a Jpeg, but a bitmap image with a .jpg extension.  Thus you still have a 4 MB file attachment.
(3,446 Views)
Hi,Ravens Fan
This Image(.jpg or .bmp) example is just for the reference that how does the problem appear,
Please provide the solution
(3,429 Views)
You don't understand.  There is a ban on posting bitmap images.  Why?  Because they are huge files that take a lot of space on the NI servers and take an unnecessarily long time to download.
You need to post the image as a .jpg or .png.  Those image files take up far less space.  .PNG files are the best for things like LabVIEW diagrams where there are distinct, sharp graphics.  The file is the smallest and there are no artifacts from the compression process.  JPEGs are usually better for photographs.
Attached is your image resaved as an .png file.  Others can download this image instead.  You'll notice that it is 1/42nd the size of your original bitmap image.  (By the way, a real jpeg of your bitmap is about 1/18th the size of the original file.  Smaller, but not as small as a .png).  Saving a bitmap and giving it a .jpg extension is NOT the same as saving it as a JPEG.  It is still a bitmap but with a phony extension.
(3,411 Views)
