How to get Value change event from ActiveX component?
Hi All,
LV 8.6.1
I try to get value change event from ActiveX component. I have browsed forum and examples through but I can't get an idea how to use "callback  vi". E.g. in example "ActiveX Event Callback for IE.vi" there is used "callback vi". I added an example where value change event and mouse down event are programmed to event structure. Mouse down event work okay but value change not. Can someone describe what I must add to my example vi that value change event works okay?
BR, Jim
(5,385 Views)
Accepted by topic author SnowForest
Here's the solution ! "Value change event" is not performed into event structure but into "Callback VI".
(5,361 Views)
Hi, Krsone
Thank you very much. Your example works perfect. I forget to mention that I need this event also to event structure. My code structure is producer-consumer and this value change event should be passed also to queue. Should I add variable to "callback vi" or is there any easier way ?
BR, Jim
(5,341 Views)
Jim,
in order to synchronize ActiveX callbacks with the producer/cosnumer, you have to either
- create an user event in the callback and capture this in you producer  or
- obtain the queue between producer and consumer in your callback and insert the appropriate element into the queue in the callback.
I think the second option is easier to implement but is more limited in its functionality.
hope this helps,
Norbert
Norbert
Expert: Geometry
(5,335 Views)
I modified the VIs for an upcoming User Group.  As Norbert B mentioned, I used user events to signal back to the main code that we got the DTPicker change event.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(4,944 Views)
Norbert-
14 posts to go... Congratulations in advanced (pre-enthusiast)!
(4,943 Views)
