07-06-2005 02:57 PM
07-07-2005 03:04 PM
07-07-2005 04:50 PM
07-08-2005 11:59 AM
Hi-
I haven't used a LabWorks II board before, but it sounds like you're applying some external amplification before interfacing with the DAQ board. This setup is not recommended because the DAQ board itself applies amplification to the signal to utilize the full resolution of your DAQ board's input circuitry. If you are applying external gain then you will not be able to use a thermocouple input channel.
If you must use the LabWorks II system to apply some gain then you will need to read the input as a voltage and apply a scale to the reading to counteract the gain applied externally by the LabWorks II card. This means that if the LabWorks card applies a gain of 100 you will need to scale your data with a custom scale in MAX by 1/100 or 0.01. After you have the voltage you can use the Convert Thermocouple Reading VI that can be found on the All Functions>>NI Measurements>>Data Acquisition>>Signal Conditioning palette to scale the voltage reading to a temperature based on thermocouple type.
Of course the recommended method is to connect directly to the DAQ card without external gain and then to just use a thermocouple input channel.
I hope this helps!
Thanks-
07-08-2005 01:06 PM
07-08-2005 01:45 PM
07-08-2005 01:46 PM
