04-04-2017 04:43 PM
Hi:
My case is:
I am doing tensile test now, and I want to use DAQmx to acquire the load data and monitor the data, when it suddenly drop to 0, use labview program to generate a pulse signal to stop the cemara, like a trigger.
Can someone tell me some useful ways to achieve it?
Thanks a lot.
04-04-2017 06:15 PM
What kind of camera do you have and how fast does it need to respond to the load change?
04-05-2017 09:13 AM
Hello zhdhappy,
Here is a tutorial that might help you with that
http://www.ni.com/tutorial/4329/en/
In that tutorial there are a couple of ways you can do it, you just have to adjust them to your application and the signals that you are handling. Hope this helps.
Regards.
