05-24-2013 10:50 AM
I am trying to generate multiple pulse trians by DAQ assistant, but found with one DAQ assistant VI the channels have some conflict. For example, I chose two physical channels of Dev1/ctr0 and Dev1/ctr1, but their terminals are the same one, i.e. Dev1/PFI12 in my case. Also, I want to one channel to outpul N pulse, the other channel 1 pulse, but I cannnot make it, because DAQ assistant seems to only allow one same generation mode for both channels. Could someone give me some clue? Thanks!
05-28-2013 05:33 PM
Hi newxuxuxu,
Which device are you using? Thanks!
05-29-2013 11:17 AM
I am using PCIe 6363 data acquisition card.
05-29-2013 11:50 PM
Share your code...!!
05-30-2013 06:46 PM
Hi newxuxuxu,
The default output for CTR 0 is PFI 12, but the default output for CTR 1 is listed as PFI 13. I do see the behavior you are talking about with DAQ Assistant regarding N pulses versus 1 pulse. However, I was able to use two separate DAQ Assistants to set one counter for N pulses and the other for 1 pulse.
