08-05-2009 11:40 PM
08-06-2009 01:00 AM
08-06-2009 11:11 PM
08-06-2009 11:25 PM
You want to use a digitial output to put out a +5VDC signal. Depending on the size of your fan, a digital output is not going to source enough current to drive the fan. You would have to use either a relay, or a transistor to switch on and off a larger current.
What data acquisition hardware are you using? What are the current requirements for the fan? Knowing that information will be able to help to determine how the data acquisition card can drive the fan.
08-06-2009 11:51 PM
08-07-2009 06:26 AM
This question has been asked many times in this forum. But everything is simple then you know how to ;). I think you need a transistor not an opamp. Take a look at this link. It will help you http://www.me.umn.edu/courses/me2011/robot/technotes/motorcontrol/motorcontrol.html
08-09-2009 08:01 AM
I am using the H bridge for controlling my motor. But the circuit need at least 6 V to have a fast rotation. However the DAQ card can only sypply 5V. So I am using the op amplifier to amplify the voltage from 5V to 6V ad supply it to the H bridge circuit.
My problem is how to supply the dc signal to the DAQ card. So, can I use the approach I wrote before to supply the 5V dc signal to the DAQ card?
