03-09-2011 08:48 AM
I need to generate an averaged power spectrum and a filtered power spectrum using the read from spreadsheet function.
I had collected some data and I was able to use the read from spreadsheet function to generate a raw power spectrum by reading the power spectrum magnitude, and df of the power spectrum.
I really really appreciate for any help offerred.
Thanks.
03-09-2011 09:24 AM
If I get it right, you want to make a statistics over your array of data... You can insert the data into array and use the VIs from Mathematics/Probability&Statistics For example: to determine the mean value, standard deviation etc...
I hope this make sense to you.
Cheers
Angel
03-09-2011 02:57 PM
Hi Angel,
Thanks for your response. Actually, I want to plot the data in a graph, i.e. plot both the averaged power spectrum and the filtered power spectrum, amplitude vs frequency.
03-10-2011 12:48 PM
Hi tronne,
So are you having problems accomplishing the averaging and filtering, or plotting the output of the functions, or both?
Have a great day,
Chris V
03-10-2011 01:20 PM
Hi Chris,
I don't know how to plot the results that I have. I've saved the power spectrum data (using write to spreadsheet), but now I want to be able to read back my data and plot the power spectrum in a graph.
Hope you get what I mean.
Thanks for taking your time to help me.
03-11-2011 03:20 AM - edited 03-11-2011 03:21 AM
You can plot your data using XY graph. Something like this:
If your file a header, you have to remove using the Array subset function... 🙂
To make a filter just add a 'check' in the FOR loop, if the indexed value is bigger or smaller than Yo then take/use some other Yi...
Does this make sense to you?
Greetings,
Angel
