01-09-2014 08:12 AM
I am new to using NI board in develop a DC motor controller. I want to generate a PWM signals that can varying duty cycle.
The board I am using is NI-sbRIO 9632. Can I have a details direction on how to generate a PWM signals to output to control the MOSFET, thus
control the speed of the brushed DC motor.
Ronald
01-21-2014 10:15 PM
Hi Ronald,
Good day to you. Probably you can look through ni.com for examples to generate PWM output using FPGA. I came across a simple one at the search link below. Just look out for the title PWM Output with LabVIEW FPGA. I tried out the example using a sbRIO 9632 to generate PWM at channel Port5/DIO0 and loop back to Port5/DIO1. It works pretty well.
Also, for your reference, I have attached a white paper which expalins about PWM interface for FPGA.
http://www.ni.com/white-paper/3254/en/
Thank you.
Alan
