How to find whether a number in an array is odd or even
      This might a simple problem. But I'm not able to crack the issue. Any helps would be appreciated. I have got an array which produces 0 to 'n'(which we will enter. I want to check each number for odd or even and that output should be connected to a case selector( case structure or if loop). If it is true I've one connection else another. I tried quotient and remainder, but it's showing the output of the first value only. Please help me out
(2,766 Views)
Accepted by niks9792
Hi niks,
what about learning to OBEY DATAFLOW? What about autoindexing tunnels? What about polymorphism? What about using (auto)cleanup?
(You may also AND with 1 to get the state of the LSB…)
(2,743 Views)
(2,718 Views)
