04-27-2016 07:27 AM
Hi, years ago my collegue wrote a program using labview and came up with the hardware.
Unfortunately, the hardware is not working anymore and I would like to know what can Ido t find out what I need to have it replaced with newer/smaller hardware.
The setup is use to count pulses and output some calculated results on the screen.
Thank you very much for your help !!!
04-27-2016 07:37 AM
Can you give the list of the original hardware?
Epictetus
04-27-2016 08:03 AM
If you post the LabVIEW code (we need to see actual code, so you'll need to put all of the relevant VIs in a folder, compress the folder, and attach the resulting .zip file), we may be able to "guess" the device, or suggest a reasonable modern substitute. Knowing the exact device and model number would also help a great deal ...
04-27-2016 09:47 AM
Tks It is at our other office. I am hving it shipped today
04-27-2016 11:46 AM
04-27-2016 01:52 PM
Here the file
04-27-2016 02:40 PM
That is some REALLY old code (written in LabVIEW 6). And it is using Traditional DAQ. Get ready for a rewrite. You will want to fix up that VI to use DAQmx. Well, you will have to in order to use any newer hardware. I recommend you give your local sales rep a call and discuss the hardware requirements.
04-27-2016 02:55 PM
OK Thank you very much for your time. I will do.
Tks again,
