How to embedd the USB6008/9 driver in a windows ce 5.0 OS image
I want to add the drivers for USB6008/9, in a Windows CE 5.0 OS image using the Platform Builder.
So I want to know the procedures for doing this task.
Thanks.
(3,253 Views)
Hello Murilo,
I`m using it, the problem is that I have to install DAQmx Base 3.1 every time I to restart or turn on de TPC.
I also probed to copy the files (ddls and other stuff) in a Compact Flash and copy from there to the folders in the TPC with a batch file in the Start Up folder. This procedure worked, but the problem is that I have to unplug the USB6009 before a restart or a turn on. And because this problem is unaceptable, I want to make an OS image that incude the files I have to copy on every restart.
Thanks.
(3,231 Views)
Accepted by topic author Juanjo339
I had to make an OS image including the drivers for USB6008/9. I did it with the Platform Builder for Win CE.
(2,965 Views)
