How to edit the signal type of the simulate ECG express VI?
hello,
I want to edit the signal type from the front panel of the simulate ECG express VI from the biomedical toolkit, I am using labview 2017. When i convert the express VI to a sub VI so I can change the parameters from the front panel, the signal type won't change but the rest of the parameters can be changed from the front panel. So I don't really know why this happens, I would appreciate any help.
Thank you.
(1,905 Views)
The express VI uses scripting to adapt inputs and outputs when the user changes parameters. Once you use the VI created by the express VI, you loose this automatic adaptation. So you need to do it yourself.
(1,864 Views)
How can I do it then?
(1,849 Views)
Hi afok,
you need to edit the VI - on your own! 😄
using LV2016/2019/2021 on Win10/11+cRIO
(1,846 Views)
Not sure, because I don't know what changes you are making... If you post a screen shot, or the VI we might be able to help.
(1,831 Views)
