How to dynamic set waveform limited and check if in range
Highlighted
Hi all
     I have a pressure sensor project want to check press it and release it waveform different as attachment,I need dynamic input numeric in array and check product waveform if in range,clear limited_up waveform the rest data as mark,how to setup limited check as others and have a good way to handle this issue,thanks in advance!!
(161 Views)
Highlighted
upload vi for you refer,XY graph how to use Limited Testing vi to inspect if in range,thanks
(102 Views)
Highlighted
Accepted by topic author Sam.Huang
Hi Sam.Huang,
Not clear on your question but I assume you ask on how to use the limit testing VI on LabVIEW.
You can refer to the provided shipping example on LabVIEW as below. You can access it in LabVIEW installation directory or search from toolbar Help > Find Example.. and search the example from there.
  • Limit Testing Measurement VI: labview\examples\Signal Processing\Waveform Measurements
  • Limit Testing for Unevenly Sampled Data VI: labview\examples\Signal Processing\Waveform Measurements
Hope that helps.
(72 Views)
Highlighted
hello, testing
(63 Views)
