How to dynamic set waveform limited and check if in range
Hi all
     I have a pressure sensor project want to check press it and release it waveform different as attachment,I need dynamic input numeric in array and check product waveform if in range,clear limited_up waveform the rest data as mark,how to setup limited check as others and have a good way to handle this issue,thanks in advance!!
(1,069 Views)
upload vi for you refer,XY graph how to use Limited Testing vi to inspect if in range,thanks
(1,010 Views)
Accepted by topic author Sam.Huang
Hi Sam.Huang,
Not clear on your question but I assume you ask on how to use the limit testing VI on LabVIEW.
You can refer to the provided shipping example on LabVIEW as below. You can access it in LabVIEW installation directory or search from toolbar Help > Find Example.. and search the example from there.
  • Limit Testing Measurement VI: labview\examples\Signal Processing\Waveform Measurements
  • Limit Testing for Unevenly Sampled Data VI: labview\examples\Signal Processing\Waveform Measurements
Hope that helps.
(980 Views)
hello, testing
(971 Views)
