How to display labels for bar plots on waveform chart
HI
   I want to draw a Bar Chart using Waveform Chart. i was able to generate bar plots according to the values. i want to display text depicting the name of entity each bar is referring to. the text will appear near each bar plots. im attaching an image below to make the picture clear. Refer to the text marked in red circles. this is how i want to display my text
   i searched many properties for it. But there is some way to do it. Because the image was generated using LabVIEWbSmiley Happy
Thanks in advance,
Rahul Garg
(2,611 Views)
Accepted by gargrahul
Hi Rahul,
you should use a graph instead of a chart!
With graphs you can use features like embedded images, cursors (with their labels), annotations. All those features allow to place a text near the bar plot…
(2,580 Views)
WOW !
Thanks friend
annotations worked perfectly to display text near bar plots
(2,568 Views)
How did you get the text sideways?
Jim
LV 2020
(2,271 Views)
