How to determine the execution order of event structure
Vij@y wrote:
From the suggested solution, I have a new problems.
- There is a timeout event at the start up and it will keep on execute in a while loop. If I connect an array in shift register and It will produce a zero value at the finder event.
- Once I read the order of sequence in the Finder event, It should reset the all the sequence values inorder to store for next different sets of sequence.
Why are you using the timeout event?  Why can't you pass the values out to the color box in each event case?
I don't see where you are saving the sequence.  You are just saving the last value.  You need to store the events in a shift register.
Message 11 of 17
(2,015 Views)
Hi crossrulz,
Initially I want color box to indicate green color. So I created the timeout event and I placed a case structure for different color to manage. Now I realised, that timeout event is useless here. So now I placed the case structure at later of event structure.
Shift register in the VI you saw to determine which event gets executing. Depends on the numeric value from the event, case structure will decide the color to display. In the VI, no where I tried to saving the sequence. The finder event will decide the output depends on the order of previously executed events. Still i am thinking how to append previously executed events. People suggested me to go with Build array funtion. But I dont quite get it since it has only one input, How can I keep on storing the event executed.
Consider the modified VI.
Message 12 of 17
(1,998 Views)
I'm really surprised you haven't already seen how to build an array somewhere on the forums before.
See attached.  I cleaned up a bunch of unnecessary code.
Message 13 of 17
(1,992 Views)
Accepted by topic author Vij@y
That case structure really isn't needed.  As I said before, make the event structure pass out the color that you want it to be.  Put it into a shift register and then you can keep it from changing.  And since you want it to be green before you even start, initialize that shift register to be the green color.
Also, there is a Color Box Constant in the Dialog & User Interface palette that makes life a lot easier when looking at colors.
And also as we have been saying, you need to build the array, not just replace it.
Message 14 of 17
(1,971 Views)
Hi Ravensfan and Crossrulz,
Both of your VI's were the exact solution I need. Its was so simplified and I learned a lot from it. But I have another problem now.
To whom I should give "Accept as solution" Smiley LOL. Because both of you gave exact solutions back to back.
Message 15 of 17
(1,953 Views)
Definately give Kudos to all posts that were useful.
As far as the solution, mine was a little more complete, so mark mine.Smiley Wink
Message 16 of 17
(1,946 Views)
I could beg to differ on that one.  But I won't.  Crossrulz needs all the help he can get to get his post count and ranking up.  After all, he is merely a proven zealot. Smiley LOL
Message 17 of 17
(1,942 Views)
