How to detect the sign of a number?
I have output which gives either negative number or positive number. My problems is how to detect the sign of the number and output boolean value? For example if input number is negative like -23.11 I want to output false and if the number is positive like 17.99 I want to output true.
T H A N K S!
(5,191 Views)
Accepted by Jick
Test whether the number is larger or equal Zero.
(5,186 Views)
Hi Jick,
Maybe you should look at the Comparison palette.
Things like smaller/greater than 0 and smaller/greater and Equal to 0
(5,183 Views)
(5,179 Views)
Thanks guys! I tried to think too complicated. 🙂
(5,177 Views)
Message Edited by Phillip Brooks on 07-16-2009 11:08 AM
(5,142 Views)
There is also a Sign vi, for future reference.  However in this case that check against 0 gives you the boolean directly, and is more useful
Tim Elsey
Certified LabVIEW Architect
(5,133 Views)
