How to delete historical records in LabVIEW?
Help!  How to delete historical records in LabVIEW?
Message 1 of 15
(3,422 Views)
What exactly are "historical records"?
Or do you mean "historical documents"?
Norbert
Norbert
Expert: Geometry
Message 2 of 15
(3,394 Views)
There are functions in the Time Travel pallet, but use them carefully lest you cause a temporal paradox.
Jim
Message 3 of 15
(3,369 Views)
Or, if you want to avoid time travel and odd beings from outer space.  I believe the OP might be looking for this:
Also availavle in edit mode from "Files>>VI Properties"  under the Revision history button View Revision History (OR Ctrl+Y) brings up the revision history pop-up.
"Should be" isn't "Is" -Jay
Message 4 of 15
(3,351 Views)
Hm, Jeff, from that point of view (if you are correct with your assumption):
It seems the OP wants to remove any indication of work done by another developer.... Sounds like plagiarism!
Norbert
Norbert
Expert: Geometry
Message 5 of 15
(3,347 Views)
Norbert
This is why you should password protect your IP  This prevents some attempts at changing the rev history since the built in ctrl+Y revision mangler opens with disabled and greyed controls.  It sounds like you are arguing to change the "Need to authenticate before use" characteristic of the method.
Actually, that might not be a bad idea.
Message 6 of 15
(3,336 Views)
Maybe he's talking about clearing the chart history?
Message 7 of 15
(3,323 Views)
Maybe he's looking for a Memory Hole function.
Jim
Message 8 of 15
(3,306 Views)
I guess we will never know if he did find it and implement it....
http://www.youtube.com/watch?v=ku2wFaaPAzI
-AK2DM
Message 9 of 15
(3,291 Views)
WTF guys, His 1st post and judging from his name maybe language and time zone issues to boot. Nice welcome aboard.
Perhaps he wants to clear the recent documents.
Norm
Message 10 of 15
(3,276 Views)
