12-05-2018 09:28 AM
Oh yes, I see what you mean Hoohvahh - I missed the bit about 2 projects having the same source code. That's probably the best method.
Thanks.
12-05-2018 09:30 AM
I realise I can do that but I am aiming to build both executables without having to do a manual intervention. It keeps the source control happy if I don't edit anything between builds (my process does an automatic commit after a build).
12-05-2018 09:36 AM
Yes - got it now. Thank you
@Mark_Yedinak wrote:
See Hoovahh's reply. Create two projects. Each project will have the appropriate flag set. Both projects include the same source code. However, your users can get access to the full application simply by installing both versions. If the access control is critical then I think you will need some type user authentication method.
It's true, control of the application is important for the security of access but for a first attempt, two different executables will suffice. I have to get this out really fast but we may be able to consider proper authentication soon afterwards.
Thanks for your help.
12-05-2018 09:40 AM
@pincpanter wrote:
Yes, there is a way. Here is an example taken from one of my projects.
AFAIK it's an undocumented feature (at least it was when I started to use the Set Tag method).
However, it works.
That looks promising - I'll do a test ....
12-05-2018 09:48 AM
In an exe build specification there is the possibility to specify a Pre-build (and a Post-build) vi.
No manual intervention is required.
12-05-2018 09:55 AM
Yes, I use those to set the version numbers according to my source control. I could use the build number tag to specify the options.
12-08-2018 08:34 AM
This seems to work fine! Thank you.
However, it works.
12-10-2018 03:05 AM
Is there a way to create from scratches those special property?
They are not in the LabVIEW default pallet.
Benoit
12-10-2018 03:50 AM
Benoit
First, you need to enable VI scripting in the VI Server Options dialog.
Then, create a Property node as usual, selecting the desired Class etc...
12-10-2018 03:57 AM
It works now. This is how I added conditional disable symbols to a copy of the project and built it. My actual code builds several different variants but this is the essence of the technique.
Notes:
You don't have to save the symbols in frame 3 - I just did that so I could open the temporary project later and see the symbols.
If you don't save the symbols, you won't have to duplicate the project to a temporary one - just keep re-opening the original project, adding symbols, building and then closing the original project without saving.
With many thanks to those posted in here and helped me make it work.
