02-09-2006 07:17 AM
02-10-2006 04:12 PM
When you say “DAQ express” I assume you mean DAQmx, in LabVIEW 7.0 or later. You could go the route of trying to do precise software timed stuff, but using WinXP you will always run into the problems that you mentioned. Hardware timed, will always be more accurate, but setting up the control may be a bit tricky. To program a hardware timed acquisition you can either do it explicitly with the DAQmx functions, or you can use the DAQ assistant (which is an Express VI). With the DAQ assistant once you drop it down it should be pretty straight forward how to configure it, a window will pop and you will have to fill in what you want. I would also recommend taking a look at some of the shipping examples to get a feel for DAQmx programming without using the DAQ assistant. You can find these examples in LabVIEW by going to: Help Menu >> Find Example. Then from there: Hardware Input and Output >> DAQmx >> Analog Generation. If you look at the examples that are Internally Clocked, those will be the easiest to work with initially. Now I am not too sure how well this will be for stage control, generally this is done either with a motion board or if fine enough control is needed FPGA. But with those examples, it should give you a good starting point to work from.
-GDE
02-10-2006 04:27 PM - edited 02-10-2006 04:27 PM
Message Edited by GDE [DE] on 02-10-2006 04:29 PM
02-26-2006 07:58 AM - edited 02-26-2006 07:58 AM
Message Edited by help on 02-26-2006 07:59 AM
