11-21-2003 04:06 AM
11-21-2003 04:09 AM
11-21-2003 08:03 AM
11-24-2003 07:34 AM
06-04-2011 06:41 AM
Hi Feroz,
Any news with this topic?
Łukasz
06-04-2011 11:33 AM
Given that this thread is 8 years old, a lot of things have changed sice. What is wrong with the array solution given earlier?
(I am no expert here, but xnodes might be a possible solution but they are unsupported and undocumented.)
Anyway, the product suggestion center is now the LabVIEW idea exchange. If you think you have a good idea, feel free to post it.
08-28-2012 08:54 AM
Thank you for the reply. My first guess was that in case of arrays everything inside the VI should be closed in a loop and perhaps with varying number of inputs the loop could be avoided and this would improve simultaneous execution for multi-core CPUs.
Łukasz
08-28-2012 09:08 AM
lukko wrote:Thank you for the reply. My first guess was that in case of arrays everything inside the VI should be closed in a loop and perhaps with varying number of inputs the loop could be avoided and this would improve simultaneous execution for multi-core CPUs.
I would not base all conclusions on first guesses. 😮
Working with arrays is typically significantly more efficient (e.g. SIMD). We also have the parallel FOR loop where several iterations can be executed in parallel, thus fully supporting simultaneous execution.
How exactly are you expecting the code to look like if you have a variable number of connectors?
