How to create SubVI with unlimited input
Hi
I was wondering how can I create a subvi, where then I can add as many inputs as required?
For instance, let's say i want to create a subvi that calculates the mean of all the inputs connected to it.
Now, I could at one instance have 3 integers going in, at others, 5.
I know I can use an array to input numbers, but I want to be able to add scalars. (like for instance with Index Array, you can extend and enter as many indeces as you want)
Kousha
(2,856 Views)
Inputs need to be predefined.  For different data types you can use polymorphic.  You can define them and set them to a default value (like -1) and only use the inputs that are not equal to the default value.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,847 Views)
