I have a simulink model and a dll for the same built nidll.tlc. To run this dll under window platform, I follow similar procedure as I would follow for a RT target machine. Only instead of pointing it to a target machine, I leave the target machine option at 'localhost'. With this arrangement, I am able to run the dll within windows environment.
I want to create a VI executable that would do the same. I was able to create this executable. The vi exe works fine with Matlab open. Thus, the model opens and simulates as it should. Now, if I try to run the dll as earlier mechanism, then I get Error 63. LabView creates a bunch of VIs when the model is compiled. When user want to 'retarget' the simulation to RT target, he/she has to point to one of the VIs that was create (.vi) and the dll file. Should these VIs be given under Add Dynamic VI option??
Anything that I am missing? I have set the permission on the LabView for Windows so that the VIs are exported etc. I am using LabView 7.1 and Matlab6.5.1.
Following combinations are working fine:
1. LabView VI - Matlab/Simulink
2. LabView VI - Model dll (on same windows machine) No matlab open
3. LabView VI exe - Matlab/Simulink
Now the last combination of LabView VI exe - Model dll, this is not working.
AD
