How to copy single data from array in front panal while the VI is running
I have attached my VI front panal along this msg , here AI values were running now i want to copy AI0 value from front panal. how is it possible ... its urgent ..
(2,272 Views)
Copying of a single data from an array, you will have to programatically do in your block diagram
Use an index array function. Index out the 'AI0'th' element from the array and keep saving it to file, using file input functions
Hope this helps
If not, do give more details on what exactly you want to achieve
regards,
Dev
(2,267 Views)
