How to convert the pixels of a folder of PNG files in binary codeles
Hi
I'm trying to convert the pixels of PNG file to binary code and i have to do it for a folder full of PNG files. For now my VI estracts the information of the PNG in a cluster and then convert the pixels to RGB to Color and then write them in binary. The problem is that it do it only for one path.
Is it possible do it automatically for all the PNG files in the folder?
(3,197 Views)
why you do not use loop for this one ?
for calling all png of one folder you can use list folder vi with pattern of .png and then you can use
file list output terminal of this vi for convert all png
(3,190 Views)
Accepted by topic author AppenzellerMann
If you Requirement is to do existing logic for all the .png Files inside a folder (List the .png FIles and Use build path to Frame a Array of path all the png Files and then Place your Existing Logic in a loop)
(3,189 Views)
Have you tried using the Recursive File List function to get all the png files in a folder?
(3,174 Views)
Hi Greg
Recursive Function will work For taking the Files of Same category woth Full path.
To Make Very precise we can use pattern for Recursive function as *.png which will give only path for the file names with .png extension, which which avoid
get FIle Extension and Case to differentiate from other file extension
Kind Regards
palanivel Thiruvenkadam
(3,154 Views)
Thank you very much.
(3,147 Views)
For Better Understanding please find the attached Image
Kind Reagrds
(3,143 Views)
