Hi
I am using MS 1.1 version, I need to take the print of the graphs which is provided by NI. The problem here is that i need the GUI to show the graph in multicolor environment, but when i am going to print it on a paper, i should be able to convert into gray scale. Can you kindly suggest me what should be done to achieve this?
Is there any features which present in MS which can help an user to decide this conversion at run time.
Thanks & Regards
Sandy
