How to convert a string to a ten bit binary number?
Hello again!
Now we have another small problem that is very easy but we don´t manage how to do... we have a while-loop and herein we have a text-file that we read one kind of string from. Then to create an array of theese strings we tried to drag an indicator outside the loop and then rightclick on the tunnel and do enable indexing... should one not get an array out from here?? Best regards!
Message 11 of 13
(411 Views)
Hello!
Sorry I think I left my brain at home today!! Frustrating but true :P. There is no need for an answer on my question! Thanks!!
Message 12 of 13
(408 Views)
This is a similar problem to something I've just been working on. If the extra two bits from the second byte are consecutive bits then you can use masking, 'rotate bits' and 'join numbers'to get what you need.
You need to be carefull that you number representations match though, otherwise you can get unexpected results.
Message 13 of 13
(398 Views)
