01-04-2005 05:44 PM
01-04-2005 05:58 PM
rioch wrote: The files I want to convert do not even have .vi or .llb extensions. Actually, there are no extension with these files.
01-04-2005 06:50 PM
01-04-2005 09:10 PM
01-04-2005 09:10 PM
04-19-2006 07:46 PM
@rolfk wrote:
@rioch wrote:
You will actually need at least a conversion kit installation on a Mac
OS system and since you would need the conversion kit comparing to I
think LabVIEW 5 to be able to read 2.x files, I'm afraid it will only
install on a Classic MacOS system.
Rolf Kalbermatter
04-20-2006 07:17 AM
04-20-2006 11:22 AM
04-20-2006 11:39 AM
04-20-2006 01:45 PM
@Jordanyorg wrote:
... Ideally I would like to have a Mac compressed version of the kit. That way, if I run into this issue again I will be able to fix it on the spot. Like I said before, the only issue is that no Mac I've used so far(OS8, OS9, OSX) recognizes the Mac versions of the programs as executable files.
Jordan,
Do you have a working version of LV2.2.1 to verify that your files are still executable VIs? If not, Lynn's offer is a good one.
I used the kit successfully several times on several Mac's (PowerMacs 7200 and 8600 with OS8, G4 with OS9) to convert old files. The only time I encountered a problem similar to what you're describing was with a couple files on a old disk which had been corrupted.
I don't think a compressed version of the kit is available for download.
