Actually, anything before version 4, you need a conversion kit that you can get for free from NI.
The part number of this kit for Windows and Macintosh is 776874-03. VIs from UNIX must be transferred to a Mac or PC where the VI can be converted to LabVIEW 4.0 and then transferred back to UNIX. The LabVIEW VI Conversion Kit is not available in the online catalog. So you must call the National Instruments Sales Department directly to request this free conversion kit.
Converting VIs is a multistep process where VIs are mass compiled in one version of LabVIEW after another. For instance, to open VIs saved in LabVIEW 2.x, you must first mass compile them in LabVIEW 3.1.1 and then mass compile them in LabVIEW 4.0.1. After saving VIs in LabVIEW 4.0.1, you
can open them in later versions of LabVIEW.
Ed
