Hallo, RICHARD,
Du meintest am 24.10.99 zum Thema How to controll the parallel-port?:
> How can I set pin 2,4 and 6 high, and pin 3,5,7,8,9 low?
Choose the vi "out port" in advanced/memory.
If you want to control LPT1: its port address is 0x378 (hexadecimal). Pins
2 ... 9 are the date pins of this port (D0 ... D7 or D1 ... D8). Usually
they are defined as output only.
For your desired output configuration the out-byte has to be
Pin Nr
9 2
00010101 (binary)
or 0x13 (hex)
or 19 (decimal)
Viele Gruesse!
Helmut
