How to control values in a subpanel vi
This may work for me with one issue.  I don't want to run the user provided subVI at all, but that doesn't seem to be necessary.  Your solution works even if I skip the call by reference node, so that's not the issue.  The issue is that I may not know before hand what the connector pane is for the user provided subVI.  As long as it is the same as the one for the VI reference constant all is good, but if it is different, there will be an error.  The only thing that I know for sure about the subVI is that it has a constant on the front panel with a known label, which lets me find a reference to the label by searching through the list of control references on the front panel of the subVI.
Message 11 of 15
(1,949 Views)
Accepted by topic author cbfsystems
I think you'll need to abandon events and try polling the Control Value.
Message 12 of 15
(1,941 Views)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 15
(1,935 Views)
Thank you everyone for your input on this.  I learned some things - in particular how to use static references with respect to my problem.  What I think I will do for my particular application is to just read back the control value using a property node when the user is done with the configuration.  That will work fine for my application since I don't use the value for anything until the configuration is done.
Message 14 of 15
(1,925 Views)
That hurts...a bit!
There are value change events....and some .....
"Should be" isn't "Is" -Jay
Message 15 of 15
(1,921 Views)
