02-17-2010 11:46 AM
Im working with a data acquistion program, were I have three forces, wich I want to be shown as a 3D graph. Now, when I implement the 3D graph, it uses a lot of CPU power, so I would like to sample the graph slower, for example about 50 times pr second, would be enough (and would probably save some CPU power?).
I have made a test VI to try to get it working, but I cant get the loops running. The three waveform generators are to simulate the tree forces, that I will get from the DAQ assistant.
Any ideas to solve it, mabye make it on a different way?
02-17-2010 11:50 AM
02-17-2010 11:54 AM
Anything over 30 Hz is near imposible for a human to notice.
Ben
02-17-2010 11:58 AM
02-17-2010 12:32 PM
Sorry but I have not learned the 3d picture version so I can not help.
Ben
02-19-2010 03:47 PM
02-22-2010 02:40 AM - edited 02-22-2010 02:41 AM
Hi Bjarne,
I have tried your attached VI in Labview 2009 an it seems to run fine with a 3D graph udate rate at 1Hz. Can you confirm this?
Depends on your application you might want to consider multiple loops structures in Labview, where DAQ and Data presentation/Logging has their own loop for optimizing the performance.
Please let me know if this helps.
Thanks!
02-22-2010 07:46 AM
Thanks for your reply. Yea mabye it would be a good idea to split it op in loops. I have tried to do it in this vi, is it the right way to do it ? you should imagine the loop with the waveform generators as a bigger system 🙂
