How to control a simple voltage signal
Hello all,
For testing purposes, I'd like to control my 24V CC power supply using LabVIEW to adjust the signal input.  I am using a NI PCI-6025e controller and running it with LabVIEW 2009.  The big issue that I have is that I can't seem to get a proper signal to generate.  I use the 'DAQmx Generate' function and create a DC signal with an offset, but regardless of what I adjust the offset to, my power supply pumps out much more current than I've calibrated for.  I hooked an ampmeter up to the signal output of the controller and found that it's delivering as much as .75A.  Any thoughts on how I can control this?  Thank you for the help.
-Austin
(2,730 Views)
Can you post some code? Maybe you forgot to configure something.. have to you tried to control your hardware with MAX prior to attempt this with LabVIEW?
Rodéric L
Certified LabVIEW Architect
(2,726 Views)
Alright, as it turns out, the amperage reading was a mistake on my part.  There is, however, a difference in what my voltage power supply and NI controller are doing to my current supply.  I will deliver a 5v voltage signal using the voltage power supply, and my CC power supply responds perfectly.  If I deliver a 5v voltage using the NI controller, the CC power supply deals out a lot more than what I want.  Could there be a third variable that could be causing these varying outcomes that I'm not seeing?
(2,722 Views)
Check your ground, and make sure you are sending 0V and 5V (single ended) and not -5 and +5 (differential).
Richard
(2,718 Views)
