How to control a linear current at E3631A power supply by Labview
Hi everyone, I would like to control the current but during this time it varies over time linearly. I need to set an initial (different of zero) and a final current. How could I do this using the vi of the E3136A (file attached), please?
(2,203 Views)
Hello Lucas22,
Did you see the Examples installed with the "Agilent E363X Series Power Supply" Instrument Driver?
After installed, on my PC, I can found in this location. Take a look on yours:
C:\Program Files (x86)\National Instruments\LabVIEW 2017\instr.lib\Agilent E363X Series
There you can find the "Agilent E363X Series.lvproj" LabVIEW Project, with some Example VIs.
I think these examples can help you to develop a better code.
(2,134 Views)
