11-13-2017 06:33 AM - edited 11-13-2017 06:38 AM
Hi yamaeda,
Thanks for your reply but i already tried using this actually if you look the code once again you can see that i used event structure for file path control(value change option), if i do as you said what is the point in using boolean control, here i just did what you said but when i press the boolean button instead opening the file path window it shows the one button dialogue box or may be i did wrong as you've said, i have attached you a vi once again go through it.
Thanks once again,
Paul
11-13-2017 07:09 AM
Yes, i see my answer was stressed. As you're not writing anything to the file you just want to select one for later, right? Then use an Open/Create file instead. The False case is just a file path passthrough.
/Y
11-13-2017 07:32 AM
Hi yamaeda,
Sorry for asking you the same question here, but i tried that too still no luck, did you tried yourself?
Thank you,
Paul
11-13-2017 07:45 AM
Sorry, but you really do need to go back and review some Basic LabVIEW, as well as give some thought to the design of your Project (I recommend that you learn a bit about State Machines). Here are some specific "problems" (= misunderstandings):
