Yes, I did try NI spy and the lines I posted on previous message were recored by NIspy.
First a few lines are very simple commands that MAX sent and received.
Then when use labview write there are severl lines and espcially the functions are ibrda instead of ibrd, and ibwrta instead of ibwrt.
I tried eliminate all parameters that hook to GPIB write, except the address string, but from the NI spy they are the same.
There is a GPIB misc in labview, trid a few commands, still quit different from using MAX.
I am still not sure if using GPIB can make a vi the same as the communication tool in MAX. Otherwise there could be a direct tool in the labview.
