How to connect a digital signal to a notifier?
I'd like to connect a digital signal to a notifier. I have a PXI time&sync card with a digital connector PFI0. I alreday use that as trigger input in a DAQmx task. But I want to use it for triggering one more, purely software thing in my application. How do I connect that PFI0 to a notifier, occurence or similar, in order to do a certain thing when PFI0 signal goes from low to high? Should I perhaps use NI Sync, NI DAQmx, or...?
Many thanks in advance,
/Andreas
(829 Views)
/Andreas
Depending on your hardware, your DAQ board may support DAQmx Digital events. When used, a change in your digital state can trigger an event, not necessarily a notifier but the event trigger can be used as software trigger.
(789 Views)
Thank you! However, PFI0 is not in the list of my DAQmx physical channels. There are only my eight AI channels on the PXIe-4300 card.
The digital signal PFI0 is on my NI PXI-6683H timing & sync module. The PXI-6683H can be controlled using the NI Sync driver, rather than the DAQmx driver, I think.
(760 Views)
Accepted by topic author andreas_nilsson
If using a 6683, you could set up a timestamp trigger and use that for your notification. Look in the example finder for a timestamp trigger; once you get the trigger send your notification.
(738 Views)
Ah, thanks a lot!
I thought there must be a way to somehow have the software react on a digital input signal event, but could not figure out how.
(709 Views)
