09-24-2012 11:08 AM
I am planning to use labview to program an instrument made by Scientifica called Patchstar. I have followed tutorials like this:
http://www.ni.com/white-paper/4478/en
It seems that I am communicating with the device but the feedback of the device is always "±`". Even if I sent blank command, it will also feedback with the same symbol. I really have no idea what is going wrong with it.
There is one minor thing that is skeptical. According to the tutorial, it is better to stop windows from installing the default driver for the device but I dont know how to do it. This may lead to miscommunication with the device?
09-24-2012 11:21 AM
Why do you want to create your own driver instead of what comes with the device? If you go that route, you need all of the low level USB RAW protocol from the vendor. Did you get that? Yoe are wasting your time if you don't have that. Is the driver from the vendor documented? If it's a USB connection, how does that connection show up in windows device manager?
09-24-2012 11:24 AM
I guess that might be the reason. In the beginning I wasnt clear what the difference is between USB raw and serial communication.
I probably will just try a serial communcation example then.
