01-28-2016 10:28 PM
I have to get data from a server, and used to do it by putty.
I'd like to perform the process automatically, so I adopted the TCPIP protocol to write data and get data.
It is fine when the IP is IPV4, but fail if IPV6.
It seems LabVIEW does not support IPV6...
Is there other way to solve the problem?
Solved! Go to Solution.
01-29-2016 03:50 AM
You are correct - LabVIEW does not currently support IPv6. There are ideas on the ideas exchange for it which you should add Kudos to if you would like to see this feature.
You will need to use an external library (e.g. .NET, calling a C/C++ DLL etc.) to communicate with an IPv6 device.
01-29-2016 04:39 AM
@Sam_Sharp wrote:There are ideas on the ideas exchange for it which you should add Kudos to if you would like to see this feature.
Just to be more specific: Native support for IPv6
01-24-2017 10:51 AM
I'd like to share this very valuable resource from the following link, it helps me to deal with my problem of communicating with device by TCPIP with IPv6 protocol.
https://lavag.org/files/file/67-tcp-ipv6-tools-for-labview/
