How to clear the history of a chart with an array of waveforms?
  I've seen in previous postings that to clear the chart you just wire an empty array into the 'history' property node.
 Well...in my case, since I'm reading several channels at once, I have an array of waveforms. So I guess, in theory, I need to wire an empty array of waveforms into the history property.
 How do I do that? How to create an array of waveforms?
(note the broken wire in the picture, where the array of doubles should be replaced by an array of waveforms)
Thanks!
(3,307 Views)
You can right-click on the History Property Node and choose Create->Constant.
Message Edited by Matthew Kelton on 12-14-2007 11:32 AM
(3,300 Views)
Awesome!
It works!
Didn't even need to change my wire type from "dynamic data" to arrays...
Thanks!
(3,284 Views)
