How to chose which shared variables to read
I'm trying to clean up some code and I'm looking for style advice. The following code actually works as desired, but I'm wondering if there is a more elegant way to do it.
I have a number of shared variables being read from Modbus devices. The problem is that these can be turned off depending on needs. When the device is off, any vi attempting to read that shared variable waits for a time out, then gives an error.
What I have done is to put each read operation in a case structure and then have an array of booleans to say which ones are turned on (see screen shot). This works just fine, but I wonder if there is a better way to do this?
thanks,
mike
(2,344 Views)
Accepted by topic author mooseo
Replace all index arrays and cases with a single For loop and use 'i' connected to a case to choose which variable to read.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,331 Views)
