How to check duplicacy of barcode?
My barcode scanner is working properly, i want to check if the barcode i am entering using the 2d scanner is not being duplicated, such as the same barcode if read by the scanner labview should interrupt " barcode already read". Kindly help.
Message 1 of 16
(2,993 Views)
Hey,
place all read Barcodes in a 1-D Array and before adding a new one, check if the Barcode is already in the array.
Regadrs,
CMW
Message 2 of 16
(2,985 Views)
If you want to compare it to the last one scanned, you just have to keep it in a shift register.
Message 3 of 16
(2,980 Views)
how to change the string data i am getting in 1d array.
Message 4 of 16
(2,976 Views)
change to what?
Message 5 of 16
(2,968 Views)
You don't change anything. You add what you have scanned to an array. Basic LabVIEW. Have you taken any of the tutorials?
Message 6 of 16
(2,961 Views)
i am getting the data from the barcode scanner in a string format, so how do i do the above mentioned process by you sir. Sorry i am new to labview so might be wrong sometime. thanx for the help
regards
Naman
Message 7 of 16
(2,960 Views)
Hey,
here a link to the basics of Arrays and clusters
Message 8 of 16
(2,947 Views)
Thanx a lot if i still face problem i bug u again.Smiley Tongue
Regards
Naman
Message 9 of 16
(2,938 Views)
when i created my 1d array the data entery are not incrementing please help.,
Message 10 of 16
(2,913 Views)
