How to change xy graph scale label positions
LV2013
Is there a way of changing the scale label positions at design time?  The only way I can find to move them is programmatically which is not convenient.
Surely it should be possible to just grab them and move?
(6,098 Views)
Right click >> Advanced >> Customize >>  change the tool to the one showing the tweezers and you can manipulate the individual elements such as the scale label.
(6,084 Views)
But then I think you have to save the control as a new control which isn't what I want to do.
(6,076 Views)
Accepted by topic author davemnicholls
No.  You don't have to save it.  But you do need to tell it to replace the original control that exists in the VI.
(6,074 Views)
Thanks, that does work.
Unfortunately the warning about unsaved changes will be lost is somewhat misleading.
(6,048 Views)
