12-12-2007 05:59 AM
12-28-2007 03:58 AM
Hi SnowForest!
It is possible to edit share variables programmatically. You should get reference to variable. For more information check knowledge base "How do I configure shared variable properties with the DSC module 8.x?"
1) Use invoke node to open library (application class -> library -> open)
2) Get reference to variable you wish to modify
3) Use property node to modify your variable
4) Close references
I've done small example for you, so I hope will be helpfull
Martin
