Not statically, but you can do this in code:
That's a method on the left and a property on the right.
I don't know if this will work as you expect (it should change the tip strip, but I don't know if it will appear like you want it to), so you can also implement this yourself by having a string indicator which you show and move around using its properties.
___________________
Try to take over the world!
