05-05-2009 09:51 AM
Hi
I have a graphic with 501 points on X axis, and autoscale on Y, and then when i generate the graphic i see the X axis from 0 to 500.
But now i need to change the scale to see the X axis from 50 to 100....but all points need to be the same as 0 to 500.
I think what i need is just removing the strings 0 and 500 and replace by 50 to 100, without changing anythink on the graphic itself.
Is this possible on LabVIEW?
Notice that i'm not asking for a zoom on the graphic...there is no zoom, only the numbers of the X axis needs to be change after i generate
the graphic 🙂
thanks!
Solved! Go to Solution.
05-05-2009 09:54 AM
05-05-2009 10:32 AM
