10-14-2008 04:29 AM
there are serval string/number input controls on a front panel, and I want to change the tab indics of them, because some users prefer to use "Tab"-Key than using mouse by inputing and the order of these control is really not logical. But I could not find any settings as "TabIndex", is there any way to do it?
Thanks a lot!
Le
Solved! Go to Solution.
10-14-2008 04:36 AM
10-14-2008 04:38 AM
Go to Edit>>Set Tabbing Order
Also if you want to skip a control right click the control and go Properties>>Key Navigation and select the skip when tabbing option
David
