How to change the display in the waveform graph to enable higher frequency displays.
I am working with waveforms of very high frequencies upto 2MHz. When the frequency of the waveform is increased above 500Hz, the display in the waveform graph goes blank.
Please help me.
(2,386 Views)
Roopa,
Please be a little more elaborative in your question. I can't figure out what you are asking.
If possible, attach your code as well.
(2,386 Views)
Dear Labviewguru,
Thanks a lot for your response.
The problem had been technical, and it has been solved.
Actually, I didn't specify the number of samples while generating the waveform, so only frequencies upto half the default value (1000) were being displayed.
Roopa
(2,386 Views)
