How to change range of Y Axis on stacked plots
How can I programatically set range of each Y Axis on multiplot stacked
charts. Atrribute node 'Active Plot' and 'Y range' doesn't work. I can
change
Y range of the 'Plot0' only.
Message 1 of 13
(5,077 Views)
Hi Mariusz,
I have the same problem, unfortunately.
Mike Manzheliy
Automated Control Systems
> change
Message 2 of 13
(5,077 Views)
Example attached.
Mike Manzheliy wrote in message
news:3AB260BA.8FB27C4@levsha.ru...
> Hi Mariusz,
> Mike Manzheliy
> > change
[Attachment MultiScaleDemo.vi, see below]
Message 3 of 13
(5,077 Views)
Hi Craig,
thank you,
but I mean Waveform Graph, not XY.
Please try to design two generators and then display it on the same Waveform Graph
and setting different scales programmatically.
Mike
Craig Graham wrote:
> Example attached.
> > Hi Mariusz,
> > Mike Manzheliy
> > > change
> MultiScaleDemo.vi T
ype: LabVIEW Instrument (application/x-unknown-content-type-LabVIEWInstrument)
> Encoding: x-uuencode
Message 4 of 13
(5,077 Views)
Instead of 'Active Plot', use 'Active Scale'
Message 5 of 13
(5,077 Views)
I have LabVIEW 5.1.1 - is there any solution. I don't have 'Active Scale' on
my list of properties.
Uzytkownik "Dennis Knutson" napisal w wiadomosci
news:5065000000050000004F1D0000-984280909000@quiq.com...
Message 10 of 13
(5,077 Views)
Hi Mariusz,
you can solve this problem.
First of all you have to use two graphs.
The first graph for display your waveforms.
The second graph you have to paint as transparent and use only Y scale.
Then put the second graph (Y scale) over the first graph.
I designed a graph with two scales last year, it's working.
If you need I can send an example to you but unfortunately XY graph.
Mike
Message 12 of 13
(4,771 Views)
I've just tried that example with a "Waveform Graph", a "Waveform Chart" and
a "Digital Waveform Graph" and I see no problem. I've attached an updated
example that has specifically a "Waveform Graph" in it with two "Y" axes.
When you run the program a straight line is generated and the same data
plotted on both sides to verify that indeed the rescaling is working.
news:3AB265DD.538AA9C@levsha.ru...
> Hi Craig,
> thank you,
Waveform Graph
> Mike
Message 6 of 13
(5,077 Views)
Hi Craig,
see attached file, please ( Strange.vi.)
My version 6.01
As you can see the scale of the plot is changing but the waveform
don't overdrawing. It's truncated 😞
Mike
> > Hi Craig,
> > thank you,
> Waveform Graph
> > Mike
> MultiScaleDemo.vi Type: LabVIEW Instrument (application/x-unknown-content-type-LabVIEWInstrument)
Message 8 of 13
(5,077 Views)
Pop the right mouse button menu over the second plot in the "plot legend",
go down to "Y-Scale" and select "Amplitude 2". Problem sorted. Each axis can
hold more than one dataset so you have to tell the graph which datasets go
with each axis.
news:3AB5D8EB.CB527209@levsha.ru...
> Hi Craig,
> My version 6.01
> Mike
Message 9 of 13
(5,077 Views)
