How to change multiple graph displays using one graph palette
Hi all,
This is my first post in NI Cummunity forum, I would like to improve my current program which currently have 4 graphs that display different measurement.
Is there a way to just using one graph palette to zoom in 4 graphs in the same place? As I am hiding 3 graphs x axis to save some real estate in the front panel.(as figure below)
My problem now is if i zoom in the top 3 graphs, the x axis will not align with the data that I am looking at because the x axis is belong to bottom graph which doesn't get zoom in.
Boon Ping Lai
(1,055 Views)
Accepted by topic author BoonPing
Hi Boon,
just read the X scale properties of the graph with visible scale and set the scales of the other graphs using property nodes too…
(You can even use an event when the scale is changed!)
using LV2020 on Win8.1+cRIO
(1,045 Views)
Hi GerdW,
Thank you very much. why can't I think of this at the first place.
BoonPing
(1,015 Views)
